Discussion topic: Help pl
Message posted on 08 Feb 2026 04:43 PM
Help pl
Help playing recordings
Message posted on 08 Feb 2026 04:56 PM
Re: Help pl
@Mick1053 what exactly is happening when you try and play recordings?
Message posted on 08 Feb 2026 04:58 PM
Re: Help pl
When you go to play a recording it just shows a picture but will not play
Message posted on 08 Feb 2026 05:03 PM - last edited: 08 Feb 2026 05:04 PM
Re: Help pl
@Mick1053 Have you tried rebooting your main Q box ie
I have also removed your duplicate post
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
