Discussion topic: Help needed
This message was authored by: Paulmac1985
Help needed
I have cancelled my sky q mini box ive been sent a bix threw post and on the letter is says send back the equipment whats listen in the box below and its blank whats best thing do
This message was authored by: bob1234
Re: Help needed
@Paulmac1985If you have cancelled multi room Sky will want the mini box, controller and the cables supplied with it. Unfortunately you don't get a refund for the box as it is loaned and you did not buy it.
Re: Help needed
Hi @Paulmac1985
Assume that you have cancelled your Sky Q Multiscreen subscription.
Send back the mini,  remote control and HDMI cable.
Make sure you include your name and address in the return and keep proof of posting.
