Discussion topic: How can sky jus put a series on the sky store when your more than half the way through it ?
This message was authored by: Leahmun
im currently watching banshee im on series 3 episode 2 and its just disappeared series 1 , 2  & 4 are there jus not the season 3 ? But its all the sky store can some one help as i dont want to pay £25 each for this as sky already cost a fortune
thanks
This message was authored by: bob1234
Re: How can sky jus put a series on the sky store when your more than half the way through it ?
@LeahmunI am afraid no one can help, it could be for licencing reasons or just because it is what Sky decided.
@Leahmun
'Banshee' is the property of Warner Bros / HBO and it's entirely up to them to decide who gets to distribute it and how long that permission lasts.
 hi @Leahmun
Can I just mention that the series is unlikely to  have just been put in the store but likely has also been available to buy for the time it was availble via your normal subscription .
The SKY Store is to quite a degree a separate entity & has different rights for purchase vs the Satellite/On demand availability via subscription
It thus just appears that they have switched because that is where you now find the episodes
As the others have mentioned most TV & films have rights which SKY only have for limited periods - some longer than others & these can come & go.
The same behaviour happens elsewhere for example Amazon Prime where from time to time some shows are available via the Amazon Prime TV subscription but also available to purchase &  I noticed this with some seasons of Elementary where I was watching one series via it. Then it was only availble to purchase via Prime & then  after a few months came back again
thanks
iv just checked and series 1,2 and 4 are available on catch up/. on demand on sky atlantic
