Discussion topic: Help needed on technical issue
Message posted on 10 Feb 2025 03:47 PM
Our Sky Q box won't switch on using the remote controller when switched off over night. To get the box to work, I have to switch it off at the wall, leave off for about a minute and then reboot. Is this a techncial issue with the box?
Message posted on 10 Feb 2025 03:49 PM
Re: Help needed on technical issue
What time of the morning is this happening, specifically is it before 0545?
Message posted on 10 Feb 2025 03:52 PM
Mainly mid-late morning. The box responses normally to the remote control unit at all other times, but the box won't restart /switch on using the remote when switched off over-night.
Message posted on 10 Feb 2025 03:59 PM
Not what I was thinking it might be then.
Off overnight as in 'on standby' or off at the plug?
Message posted on 10 Feb 2025 04:03 PM
Off as turned off on the remote - I guess on standby. It is working normally at the moment with the remote, but will fail to start tomorrow morning when switched to standby over night.
Message posted on 10 Feb 2025 07:44 PM
My sky Qbox will not turn on I've try to reset it does not work??
