Discussion topic: Help. The website is useless
This message was authored by: sarsons
How do I contact sky by email or chat only
Re: Help. The website is useless
hi @sarsons
SKY don't use email.
I believe these are the current methods for contacting Sky. Depending on your reason for making contact some methods are more appropriate than others … ( I know this includesd phone options but others also)
call Customer Services by dialling 150 (free) from either a Sky mobile or a Sky Talk landline.
All calls will start automated which may offer you the online help route or try to send you here to the forum. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
Note: if your services are restricted due to a missed payment phone contact is unlikely to work.
online help via this link
https://www.sky.com/help
At the end of the help it MAY provide a phone number if it's appropriate.
 Sky Assistant is now available at the top of sky.com/help (or as a chat bubble bottom right if used before) for most service issues and gives you 24/7 help and a quick response. It will provide you with multiple choice options based on your problem and will provide troubleshooting steps to fix any service issues.
Social Media You can also get in touch via the messaging services on: Facebook, Instagram, or X (links at the bottom of the forum page).
Is there anything the community here can assist you with ?
@sarsons
Sky don't use email as they can't verify you are the account holder. Is your issue something we can advise on?
These are the current methods for contacting Sky, and depending on the issue some will be more appropriate than others …
🟣 📞 Customer Services by dialling 150 (free) from either a Sky mobile or your Sky Talk landline if you have Sky Broadband. The forum doesn’t allow the display of other numbers but official numbers to Sky from the UK are 03 numbers which are usually inclusive from non Sky phones.
All calls will start automated (aka ‘the bot’) which may offer you the online help route or try to send you here to the forum. Stay on the line as long as possible and sometimes saying nothing when asked the reason for the call helps being put in the queue for an agent.
🟣online help via this link
🟣Sky Assistant 💬 should also be available via
🟣Social Media You can also get in touch via the messaging services on Facebook or Instagram, (links at the bottom of the forum page).
🟡Note ~ ROI customers If you’re in the ROI make sure the flag in the bottom right of any link is showing the correct flag and change if required. The Sky Ireland phone lines have different operating hours to the UK and are closed at a weekend.
▪️I AM NOT A SKY EMPLOYEE ▪️
