Discussion topic: Hello, my multi room isn’t working.
This message was authored by HarryArnot This message was authored by: HarryArnot
Hello, my multi room isn't working.
I think it seems to be a problem with the box receiving instructions from the remote. The remote is working because when I turn volume up/down or press the source button it works. But I can't get out of set up mode? I've tried rebooting the main sky Q box but this hasn't helped.
Re: Hello, my multi room isn’t working.
Hi @HarryArnot
First reboot the mini again.
When the mini is back on with Green led
If you still cannot get past the 1 of 4 step try resetting the mini remote to infrared mode by pressing and holding 7 & 9 on the remote until it's led flashes 4 times.
Then try the 1 &4 again and see if the box respond to the remote.  (Make sure that you are pointing the remote at the mini as infrared mode needs line of sight).
Also bear in mind that when it tells you to press the WPS it means on the main Q box).
If this gets your mini working you will need to re pair the mini remote for Bluetooth.
Make sure that you are pointing your remote at the mini box and press 1 & 3 together until the remote led flashes and follow onscreen instructions to re- pair.
This message was authored by Hollienjoshua This message was authored by: Hollienjoshua
Re: Hello, mywe have tried to reboot the main box but it's still not working multi ro isn’t working.
Our multi room box is saying mr104 error
This message was authored by Chodley This message was authored by: Chodley
Hopefully someone will split this out into its own thread as it's not related to the OP's issue but you probably ended up here because of the suggested topics that come up when you type in a subject.
Has it ever worked?
This message was authored by 1718 This message was authored by: 1718
No sky in my bedrooms, main tv working fine tried rebooting nothing seems to work
