Discussion topic: Having to keep resetting sky Q mini box
This message was authored by: Robbo0410
This is extremely frustrating, every now and again the mini box will lose connection to the main box, both boxes have been replaced I was having issues with the mini box knocking the WiFi off but after calling Sky they put me through to an engineer who advised me to turn the 2.4ghz channel off on both boxes, this solved it for a few days but now it's happening again, what's even worse is that it freezes the entire box, can't pause if your watching anything on demand it'll just continue to play once the connection is restored and then if I press the home button it just brings up a black screen, can't power it off either as that does not work, only way I can solve is by pulling the power cord out, main box is fine though, is this a known issue with the mini box, I'm having to do this few times a day it should not be losing connection at all I have full fibre broadband, any suggestions I think the WiFi is still dropping out on the router, they suggested replacing the router but they don't think that's the problem
Re: Having to keep resetting sky Q mini box
Hi @Robbo0410
Reboot the mini as above.
Avatar for Robbo0410
Level 4 icon
@oldfella this is only happening when the WiFi is dropping, hence why I said that Sky don't think it's a router problem they thought it had something to do with the boxes, they advised to the 2.4ghz off on the boxes which solved it for a few days but every so often the WiFi drops on the router, it's back on within 30 seconds, the mini box is only what I said in original post when the WiFi drops, I'm not sure if it's worth calling Sky and requesting a broadband engineer visit as I'm on full fibre the connection should not be dropping at all, and it's obviously causing a knock on effect problem with the mini box, I'm not a massive expert on broadband settings on any router nvm Sky's own
