Discussion topic: Having sky q installed
This message was authored by: warkworth7
Were having sky q installed, but just wo dering if we will lose all our recordings on our sky + box?
Many thanks for any help
Re: Having sky q installed
hi @warkworth7
Unfortunately yes - all recordings are stored on the Hard disk and can't be transferred.
You will be able to download any purchased recordings and some may be available in Catch Up or On demand to download on your new box
Avatar for warkworth7
Thanks so much for your reply, i sort of guessed that may be the case🙄 have to have a look what weve got on there😁
Cheers
Cheers
Also make sure you note down any planned/series links so you can set them up.
