2
This discussion topic has been answered Discussion topic: I cannot connect the Sky Q box and mini box to tge internet. No catch up or Apps for 3 days.
This message was authored by: Debmason
Re: I cannot connect the Sky Q box and mini box to tge internet. No catch up or Apps for 3 days.
Hi @Debmason
First step is connect your Main Q box.
Assume you have carried out a Network reset on your Q box exactly as follows.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
Hi @Debmason
Avatar for Debmason
