Discussion topic: Hard disk drive
This message was authored by: George2F
Hard disk drive
I keep having problems with the hard disk drive, I have carried out a reset of the hard drive and has not fixed my isssue
Re: Hard disk drive
If you have tried all the reset hard drive options as described here, the next step would be  a replacement Sky Q box, an online form is at the bottom of the Sky help article:
https://www.sky.com/help/home/sky-tv/sky-tv-q/fixing-sky-q/fixing-recordings-and-downloads/fix-a-pro...
When the courier does the Sky box swap on your doorstep, remember to keep hold of your Sky viewing card.
You will need this for the replacement box.
