Discussion topic: Hard disc drive
This message was authored by: Karenjermy
Hard disc drive
How to reset without deleting everything that's recorded? At the moment I can get into my recordings to delete anything ?'
Re: Hard disc drive
Hi @Karenjermy
Only a Reset Settings will preserve your recordings.
However if you have Hard drive issues this is unlikely to solve your problem.
No harm in in trying a Reset Settings in the Q box hidden menu.
