6
This discussion topic has been answered Discussion topic: Hard disc drive problem
This message was authored by: Mfcolldunc26
In recent days we have twice lost all previous recordings, and now have no access to Record or In Demand and Catch Up, because of a 'Problem with Hard Drive'. We have followed all the advice steps for this issue on our Sky Q Multi Room and have done all the resets, but the problems have not been resolved. The robot helpline has been useless and trying to speak to a human has tested our patience to the limit. Feel like pulling the plug on Sky.
This message was authored by: Laing1 Answer
Re: Hard disc drive problem
@Mfcolldunc26 have a look at the link below by following it then it will eventually lead you to odering a new box
https://www.sky.com/help/sky-tv/sky-tv-q/fixing-sky-q/an-on-screen-message-sky-q/articles/sky-q-hard...
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
@Mfcolldunc26
If you do end up needing a new box it'll probably be via a 'doorstep box swap' whereby a courier company (usually DPD in the UK) deliver a new box and take your pre-disconnected faulty box away so remember to remove the viewing card from the old box before it disappears into the van. Also accept the power cable the courier brings in case it's a different fitting to the one you have.
This message was authored by: Ang60
We keep losing sky connection or a hard disc problem
Have you followed the advice given earlier in the thread?
Yes and it still isn't working, the tv keeps freezing now so we have to keep turning the power off. This has been happening for months if I see know improvement I will have no choice but move to another supplier
@Ang60
That link may lead to a doorstep box swap as described above.
Answered - Go to Answer
