Discussion topic: Hard Drive Failing
Message posted on 04 Nov 2024 09:54 AM
Hard Drive Failing
What are the signs that the hard drive in my Q box is starting to fail?
Message posted on 04 Nov 2024 10:04 AM
Re: Hard Drive Failing
Hi @Jasper2344 You should be receiving error messages on screen.
Message posted on 04 Nov 2024 10:05 AM
An error should display but possible symptoms are:
Recording failing
Unable to rewind live TV
Mini boxes not working
Extended time switching channels
Message posted on 04 Nov 2024 11:08 AM
Thanks @PandJ2020 @MightyQuinn for the info. Im just concercened as when i fast forward it doesnt seem as fluid as it used to be if that makes sense.
Message posted on 04 Nov 2024 11:35 AM
You could always try a hard drive reset, often helps with such issues.
Follow the Sky help instructions here;
Remember: Resetting your hard drive will delete all:
- Recordings
- Downloads
- Purchases
- Reminders and series links
You can restore Buy & Keep purchases from the Sky Store website
