Discussion topic: Handset not communicating with box
Message posted on 28 May 2024 11:36 AM
Handset not communicating with mini sky box
Message posted on 28 May 2024 11:38 AM
Re: Handset not communicating with box
Mini Sky Box is not responding to handset. Batteries are fine.
Message posted on 28 May 2024 12:11 PM
Hi @Fraser7
Have you tried pressing the Standby button (Amber led) on the front of the mini box.
If this turns the mini box on
With the mini box on with green led try completly resetting your mini Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
