Discussion topic: HDCP Message
Message posted on 01 Sep 2023 07:38 PM
HDCP Message
I've started to get the following message intermittently when I turn my Sky Q box on: -
This screen does not support HDCP. Try reconnecting your HDMI cable or use a different screen.
My TV was brand new in February and I have replaced the HDMI Cable and changed the socket it goes into on the TV. It seems the only way to clear is rebooting the box for about 5 minutes. Whilst this resolves the issue it is a bit of a pain.
Any ideas?
Message posted on 01 Sep 2023 07:57 PM
Re: HDCP Message
Any TV bought in the last 3-4 years will have support for the right version of HDCP on all the sockets so it won't be that (though sensible to try in case of a fault on a socket)
What TV is it and what cable did you use?
Sounds like maybe an issue with the box itself.
Message posted on 01 Sep 2023 07:59 PM
Re: HDCP Message
It's a Panasonic although I don't know the make of HDMI cable.
Message posted on 01 Sep 2023 08:07 PM
Re: HDCP Message
@Wales wrote:It's a Panasonic although I don't know the make of HDMI cable.
But it's a certified high speed cable?
Message posted on 01 Sep 2023 08:08 PM
Re: HDCP Message
I believe so. It was supplied by the company from whom I bought the TV as I've had them to come out and check all was ok with the TV.
Message posted on 01 Sep 2023 08:46 PM
Re: HDCP Message
Hmm
think I'd be trying one I know about like
Message posted on 01 Sep 2023 08:47 PM
Re: HDCP Message
Very many thanks 🤞
