Discussion topic: Gurdarshan
Message posted on 15 Apr 2023 12:28 PM
Gurdarshan
How to get sky pin online
Message posted on 15 Apr 2023 12:32 PM
Re: Gurdarshan
What do you mean by Sky pin?
Do you mean the pin number you enter into the TV for watching certain films/shows?
My views are my own and I will assist where possible.
Sky Q 2TB UHD, 2X Mini Box, Sky BB UF1, Booster 4
I am just a customer, If I've got something wrong feel free to tell me, If I've something right mark it as an answer
Message posted on 15 Apr 2023 12:34 PM
Re: Gurdarshan
I don't belive you can view your current pin - https://www.sky.com/myaccount/tv
But on that link you can reset your TV pin.
Message posted on 15 Apr 2023 12:37 PM
Re: Gurdarshan
You can change your Sky pin online and via your Sky Q box.
All detailed here;
Your Sky PIN | Sky Help | Sky.com
Message posted on 15 Apr 2023 12:49 PM
Re: Gurdarshan
@gurdarshan if you need your pin number it is normally the last 4 digits of your viewing card number which if you are close to your q box can be found by press the home button scroll to settings then to system information
or online by going to the link below then manage my tv settings
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
