Discussion topic: Got sky multi screen. just added sky premiership. now multi screen doesn't work. not happy.
Message posted on 02 Sep 2023 04:16 PM
Got my multi screen a few weeks back . son set it up working fine. Just added sky premiership doesn't work. tried calling and got the robot who promised to send me a text to help me. After 2 calls nothing. NOT HAPPY WITH LACK OF SUPPORT
Message posted on 02 Sep 2023 04:19 PM
Re: Got sky multi screen. just added sky premiership. now multi screen doesn't work. not happy.
Hi @WestHam15
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box
