10
This discussion topic has been answered Discussion topic: Gold HD briefly loosing signal 18/07
This message was authored by: Annabel+L
Gold+1 keeps briefly losing signal tonight, screen goes black then pic comes back, anyone else?
This message was authored by: Daniel-F Answer
Re: Gold HD briefly loosing signal
Posted by a Sky employee
Hi all,
Thanks everyone for confirming the issue with Gold HD from over the weekend.
We had this checked and the issue cause has been identified and looks to be fixed from our end now.
If anyone is still experiencing the issue with Gold HD however please do reach back out and confirm 🙂
Thanks,
Daniel
Community Moderator
Re: Anyone having this problem with HD GOLD
@Annabel+L
There are no +1 channels on Glass or Stream. So I assume you have Sky Q which is a totally different method of delivery (via satellite rather than broadband).
MikeAlanR
Re: Gold+1
I've not noticed it myself as I haven't been watching that channel, but I have seen some comments about the UKTV channels including Gold dropping out and going blank  today on all platforms, so it may be related to that.
@Annabel+L  Your post has been moved from a thread you added to in the Glass section as Glass/Stream has no +1 channels so is not relevant to that particular platform.
Your duplicate thread has also been removed.
This message was authored by: GrahamTB
Re: Gold HD briefly loosing signal 18/07
Yes Sky Gold keeps dropping out, think I need a refund!
Gold is part of the UKTV group (not Sky) and their channels have been having intermittent issues for a few days.
https://corporate.uktv.co.uk/about-uktv/our-channels
This message was authored by: twilight+princess
Same here. Must be a UKTV problem.
Virginia.
I don’t work for Sky.
If I have helped then please leave a like.
Hi all,
Thanks,
Daniel
Community Moderator
This message was authored by: NDG+1
I seem to have lost Gold HD as it comes up with a signal issue on my Sky Q box / dish ??
Any fixes out there ??
@NDG+1
A message displaying ”no signal” tends to be generated from your TV and normally means your TV’s not seeing the Sky box on the relevant HDMI input.
If a message displays “no satellite signal” it relates to your Sky Q box, so firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s likely to be a dish alignment issue so check the troubleshooting in this link
If you are connected to a communal dish you need to liaise with your building management company / landlord who will have their approved engineers to contact.
Remember, a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
Thank you for the update, interesting that Gold +1 works fine and there does not appear to be any other channels that are not working.
Answered - Go to Answer
