Discussion topic: Gofibre issues
This message was authored by: Gabriel1980
Gofibre issues
Hi All,
I've got a SKY Q box and I recently had GoFibre installed (they are the only company to offer fibre broadband in my area).  Installation of GoFibre was a trial in itself (several appointments missed and various days off work), but got installed eventually.  GoFibre engineer connected it to the Sky box and off I went.
Shortly after I noticed that various apps through Sky (primarily Disney+ and Amazon Prime) started pixellating intermediately.  It happened often enough that I would access the apps directly through my smart tv,  where the problem was absent.  No problems with any other device.  Ran a speed-test - no problems there.
Contacted Sky who sent out two engineers.  They couldn't fix the problem so ordered a new Sky Q box - problem still persisted.  Tried connecting directly to router with an ethernet cable.  Problem still presists.  GoFibre keeps telling me it's a Sky issue and has exhausted all it's trouble-shooting.  Any advise on how to fix this issue?
This message was authored by: JibbaJoy
Re: Gofibre issues
hi @Gabriel1980 , there is an issue with the original SkyQ boxes showing artifacts on streaming channels and it been going on for 3 months now.
Some users, including me, have reported the problem is solved by changing the Q box out for a version 2 unit; this unit has an external PSU.
What hardware version is your replacement box?
SkyQ [H/W: 32B106] + 3 mini
Samsung 55" Neo QLED UHD TV
Swish Fibre 150 Symetrical
Linksys MX5400 Mesh network
This message was authored by: Mans23
Re: Gofibre issues
We are having exactly the same issue. We have Sky Q and recently moved to Go Fibre and we keep losing connection to the internet. I think we've tried everything. Pe4haps we also need a new box.
Re: Gofibre issues
We are having exactly the same issue. We have Sky Q and recently moved to Go Fibre and we keep losing connection to the internet. I think we've tried everything. Perhaps we also need a new box.
This message was authored by: DaveDrizen
Re: Gofibre issues
@Gabriel1980 wrote:
Hi All,
I f you have the apps are your smart tv why not view them on there? You will probably get a better quality picture an there even  if there was  no pixelating. I have a fire stick now no longer use the apps in the sky box. It lot easer to  access than doing on the sky Q box anyway.
