Discussion topic: Glitching sound
This message was authored by: Blammers
Glitching sound
Nothing has changed with my setup and this was working perfectly yesterday, bit today the sound is glitching on both live tv and recordings
Re: Glitching sound
@Blammers
Try a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
