Discussion topic: Garden room mini box
This message was authored by: Leebro12
Hi. I have run a cat6 cable from my main router(bt) to my new garden room. I can't connect my mini to the main skyq box in the house. Can anyone help please
lee
Re: Garden room mini box
lee
hi @Leebro12
Is the Main box also connected to the router via ethernet ?
If not you need to know that when your provider is not SKY then the mini & the main box must be connected on the same network both via ethernet (if using it). This can be mini direct to main box, or both main & mini connected to the router or unmanaged switch(es) on the same network
Avatar for Leebro12
Hi there.
thanks for the reply. My main box is connected to the main router, via etherneet, but I have been trying to connect the mini via wifi. Do I need to run another cat 6 from the mini to the main bt routher. I have connected a tp link ac1200 today. Can i connect from that. My ethernet from my main bt router runs to the tp link
@Leebro12 wrote:
Hi there.
hi @Leebro12
I am sorry but now I am slightly confused as your opening mentioned cat 6 from Garden room to the Router but you are now saying you are trying to use wifi to connect the mIni ?
Is the mini not connected to ethernet in your Garden room
Most people do find trying to connect a mini box to the main box via wifi is too far.
You may also need to be aware that when your provider is not SKY the minis won;t connect to your home wifi but instead a wifi signal generated by the Main box
Personally I am not that familiar with TP link connectors but AFAIK you can use Powerline  adapters anywhere you would use full ethernet (providing the mains cables are connected to the same MCU)
Avatar for Leebro12
Hi
my mini isnt connected via ethernet. Mini is trying to connect via WiFi
can i connect the mini to the tp or do i have to run another cat6 from main router bt to mini or from the sky q box to mini
lee
@Leebro12 wrote:
Hi
lee
hi @Leebro12
I think I understand now.
If, as I understand it the Cat 6 from your Garden room is connected to the router (or elsewhere on your home network that also connects to the router) then you can use the same ethernet to connect your mini - you might need an unmanaged switch in the Garden room to allow this
Once connected via etherent you may need to disable wifi on the mini to force it to connect viia ethernet rather than it try to connect to your Main box's wifi - if so let us know
Avatar for Leebro12
Okay, so I am confused now lol. I have run a cat6 from my bt router, (main box)to my tp link ac1200 which allows another wifi access plus 4 ports. My mini is trying to connect to the main q in the living rm which is too far away. Can I connect my mini to the to link or do i need to run another cat6 from mini to main (bt) router in the house
tia
tia
Hi @Leebro12
Q boxes (if using WiFi) will not connect to 3rd party routers or 3rd party WiFi Access points.
If the mini and the main Q box are connected to the 3rd Party router by Ethernet then you should be OK
tia
@Leebro12  providing you connect the mini via ethernet to the TP Link which is then  connected via ethernet to your router (which you say the main box is connected to via ethernet)  I think you should be OK
(i.e. The Tp Link acting as a switch in this case)
Avatar for Leebro12
@nigea99 Thanks for the help. I'll update tomorrow
lee
