Discussion topic: GQ - No Sky reception
This message was authored by: JCorfu
Sky sends signals No satelite connection to my TV and then I have no reception for certain channels.
Re: GQ - No Sky reception
@JCorfu
If you are new to the forum then welcome to the Community, which is predominantly made up of Sky customers helping other Sky customers. You aren’t talking to Sky by posting here.
Your post is a little unclear. Whats GQ in the thread title?
I'm afraid Sky no longer support Sky+ and Sky+HD set ups (where you've posted).
You'll need to employ a local satellite engineer at your own expense to; check / realign / repair / replace the dish, perhaps repair or replace the LNB if that's the problem, or check the cables for water ingress.
If you have Sky Protect cover through Domestic and General Insurance you can call them but a customer previously posted on here that they wouldn't send an engineer - but they did offer the customer £65 towards arranging one themselves.
The alternative is contacting Sky to upgrade to Sky Q or change to Glass / Stream. If you upgrade to Sky Q any dish, LNB or cable issues would be sorted out f.o.c as part of the process.
@JCorfu
I see your thread has now been moved from the Sky+ board to the Sky Q board so which do you have?
