Discussion topic: Full screen
Message posted on 01 Sep 2026 08:15 PM
Full screen
Selected a football match on sky sports + how do you select a full tv screen what button do I press
Message posted on 01 Sep 2026 08:22 PM
Re: Full screen
I don't think you have Sky+ (where you've posted).
Sky+ customers cannot receive red button sport. Customers with Sky+ (with the full sports subscription) will only receive the Sky Sports+ Channel (channel 404), but will not have access to the live streams of any other games on simultaneously as Sky+ is not compatible.
Do you have Sky Q?
Message posted on 05 Sep 2026 06:46 AM
Re: Full screen
Must be sky Q I have definitely got red button I chose the game then unable to select to watch it with the whole screen thanks
Message posted on 05 Sep 2026 07:00 AM
Re: Full screen
If you have the side bar showing whilst watching red button content just press the dismiss button a couple of times on the handset and the full screen will be displayed.
Message posted on 05 Sep 2026 09:08 AM
Re: Full screen
What's the dismiss button?
Message posted on 05 Sep 2026 09:14 AM
Re: Full screen
It's to the left of the home button in the middle of the remote, the icon is like a square with an arrow pointing out.
Message posted on 05 Sep 2026 11:32 AM
Re: Full screen
@GeorgeA123 wrote:Must be sky Q I have definitely got red button I chose the game then unable to select to watch it with the whole screen thanks
I believe that if you go into the feed directly via the Apps section (rather than going via a channel's red button) then you don't get the sidebar.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Message posted on 16 Sep 2026 07:56 PM
Re: Full screen
Thank you, that worked for me. Clicked it twice and then got full screen.
Not very obvious from Sky, they should change this.
Thank you again
Message posted on 22 Sep 2026 08:19 PM
Re: Full screen
Thanks absolute pathetic from Sky they way they have done this with no clue
Message posted on 23 Sep 2026 08:28 AM
Re: Full screen
@Burton+Villain wrote:Thanks absolute pathetic from Sky they way they have done this with no clue
Why do you say that? You have to press the "dismiss" (or "back button as it's sometimes called) when you turnSky on to get out of the mini TV screen mode; it's just the same for this
