Discussion topic: Full screen
This message was authored by: GeorgeA123
Full screen
Selected a football match on sky sports + how do you select a full tv screen what button do I press
Re: Full screen
@GeorgeA123
I don't think you have Sky+ (where you've posted).
Sky+ customers cannot receive red button sport. Customers with Sky+ (with the full sports subscription) will only receive the Sky Sports+ Channel (channel 404), but will not have access to the live streams of any other games on simultaneously as Sky+ is not compatible.
Do you  have Sky Q?
Avatar for GeorgeA123
Re: Full screen
Must be sky Q I have definitely got red button I chose the game then unable to select to watch it with the whole screen thanks
Re: Full screen
@GeorgeA123
If you have the side bar showing whilst watching red button content just press the dismiss button a couple of times on the handset and the full screen will be displayed.
This message was authored by: Jinxxed
Re: Full screen
What's the dismiss button?
Re: Full screen
It's to the left of the home button in the middle of the remote, the icon is like a square with an arrow pointing out.
Re: Full screen
I believe that if you go into the feed directly via the Apps section (rather than going via a channel's red button) then you don't get the sidebar.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
