Discussion topic: Frustrating Sky Q
This message was authored by: Fedup2025
Frustrating Sky Q
For several weeks my Sky q tv will just close down then open on the apps home page but I cannot do anything to move on.  I have to turn everything off, wait and then turn back on.  I am fed up my subscription costs a fortune and I can't get direct help.
Re: Frustrating Sky Q
@Fedup2025 You could try resetting the settings in the Q boxes hidden menu.
To enter the hidden menu press the home button and scroll down to settings but do not select settings.
With settings highlighted press 0 0 1 then select
Only Carry out the first Reset being Reset Settings as the others will wipe all recordings.
After the reset you will have to re-pair your remote assuming you are using a bluetooth remote by pressing 1 and 3 together on the remote
Avatar for Fedup2025
Thanks very much I will try that
Does sound like the box may be starting to fail
