Discussion topic: Frustrating Sky Q
Message posted on 18 Aug 2025 06:23 PM
Frustrating Sky Q
For several weeks my Sky q tv will just close down then open on the apps home page but I cannot do anything to move on. I have to turn everything off, wait and then turn back on. I am fed up my subscription costs a fortune and I can't get direct help.
Message posted on 18 Aug 2025 07:57 PM
Re: Frustrating Sky Q
@Fedup2025 You could try resetting the settings in the Q boxes hidden menu.
To enter the hidden menu press the home button and scroll down to settings but do not select settings.
With settings highlighted press 0 0 1 then select
Only Carry out the first Reset being Reset Settings as the others will wipe all recordings.
After the reset you will have to re-pair your remote assuming you are using a bluetooth remote by pressing 1 and 3 together on the remote
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 18 Aug 2025 09:06 PM
Thanks very much I will try that
Message posted on 18 Aug 2025 09:33 PM
Does sound like the box may be starting to fail
