Discussion topic: Freezing software 350
This message was authored by: DigiDumb
My Sky Q box keeps freezing. Software version Q350. 000.12.00L (679jvlc). Hardware version. 32B12D.
I tried to turn my Sky Q box on this morning and it would not respond. This is happening every day. Sometimes it happens whilst I'm watching a programme. It just freezes.
also find sky box whirring uncontrollably at 3am each morning.  Plus, messing with my mini connection all the resets.
clearly a software issue - how do I fix it?  I've disconnected lan, changed power save mode.
Re: Freezing software 350
Literally millions of other boxes will have the same software: as no-one else has posted I'd think it's much more likely to be an individual hardware problem, to be resolved by a swap-out.
Avatar for DigiDumb
Yes they have.  Literally was able to copy someone else's post
Hi @DigiDumb   If there was a software issue there would be a melt down of posts in the community, hundreds, if not thousands. If you feel you have a problem, I would report it to Sky.
