5
This discussion topic has been answered Discussion topic: Can't watch TV as there is connectivity problem??
This message was authored by: Ady_M
I cannot watch any television as it says in Sky "You can't watch TV at the moment as there is a connectivity problem". I've restarted the router and the Skq Main box but still the same issue. WiFi is working fine. But main box and mini boxes are not working. Any help anyone??
Re: Can't watch TV as there is connectivity problem??
Hi @Ady_M
Try a Network Reset found in main Q box Home - Settings - Setup - Network.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
Hi @Ady_M
Avatar for Ady_M
Level 0 icon
Nice one Pal!! Appreciate it!
This message was authored by: medea
the screen says in cannot fnd my new Sky Q box on the network
ERROR MR104
I have switched off all the plugs and boosters and put them on again.  No change.
I do not know how to open or activate my sky Q box, or the little booster box on top of it
This message was authored by: Lizzie371
We have a blue screen and no satellite signal.
The message says the channel is currently affected by a problem with our satellite signal.
We have turned the router off and back on again and we have turned the main box and tv off and back ion agsin.
@Lizzie371 have a read through the link below it should lead to booking an engineer
https://www.sky.com/help/articles/signal-error-messages-on-sky-q
