Discussion topic: Freezing Sky Q Box requires rebooting
This message was authored by: MrsT1980
My sky q box keeps freezing so I have to turn it off at the mains leave it and turn back on after a minute. It's really annoying and sometimes doesn't record
Re: Freezing Sky Q Box requires rebooting
Hi @MrsT1980
