6
This discussion topic has been answered Discussion topic: Freevee
This message was authored by: paulm12
Freevee
Hi all, I see Amazon have introduced a new service Freevee as an App. is there a consideration for Sky to install this App?
This message was authored by: best+of+the+best Answer
Re: Freevee
Hi @paulm12 Amazon Prime Video is an app on the Sky Q box and Freevee is there
Prime Video home screen scroll down to free with ads that is the Freevee app on Sky Q via Prime no consideration needed as you can access it already.
Freevee via Amazon Prime Video via Sky Q box
Re: Freevee
Avatar for paulm12
Re: Freevee
Thanks for the reply and the information, it's nice to know that there are people out there prepared to share the information that they have, I appreciate your help.
Re: Freevee
Freevee works fine on Sky Q.
You do though still need to sign in with a current Amazon account to view any of the free with ads content.
There is quite a lot of good TV series and Movies on there and the ads are not that intrusive.
Do like the way the ads in bottom left have a countdown to finishing
Avatar for paulm12
Re: Freevee
Hi, Thanks for the additional info.
This message was authored by: My+Phone+NUMBER
Re: Freevee
Can I get free vee on sky glass
This message was authored by: Jones_The_Cat
Re: Freevee
Yes, via the Prime Video app.
As others have noted above, you need to have an Amazon login to allow you to access the Prime Video app in the first place, then scroll down the menu page to the FreeVee section.
