Discussion topic: Flashing wps light
Message posted on 24 Jan 2025 10:04 PM
Flashing wps light
My new sky q box isn't working wps light flashing
Message posted on 24 Jan 2025 10:21 PM
Re: Flashing wps light
Hi @Ells812
Are you trying to connect it to your router ?
If so,
