Discussion topic: Flashing red light
Message posted on 24 Sep 2025 08:08 PM
Flashing red light
I had fibre installed recently and since the engineer input the new wifi password into tv I have a constant flashing red light on the front of the tv? It's not the remote as I've put new batteries in
Message posted on 24 Sep 2025 08:17 PM
Re: Flashing red light
Hi @Lin75
If the flashing red light is on your Television set then it is nothing to do with Sky Q.
Normally on a television, if it is on the lower front edge it relates to some sort of television error.
Try rebooting your television set by removing its power lead for 30 seconds and then reconnecting. See if this clears it.
Otherwise you need to refer to you television manual to check for error code indications.
