Discussion topic: Film 4 no longer available on sky platform
This message was authored by: Hillfort
Why are Sky not officially giving a reason why Film 4 is longer available on its platform. Perhaps their customers should have a look at other suppliers.
Re: Film 4 no longer available on sky platform
hi @Hillfort
Film 4 is available (in HD)  - on my SKY Q box it is on channel 313 - I guess it may be different on SKY +
Channel 4 are cutting costs and stopped some of its SD versions via Satellite (this is nothing to do with SKY itself)
@Hillfort  Film4 in sd is still available on 313 on my sky+hd box
Works just fine for me too.
SD version is on 855?
@Hillfort what issue are you having, perhaps it's a dish alignment problem?
@Hillfort
Works fine here on Sky Q so what's happening when you try to view it?
Avatar for Hillfort
Level 2 icon
If Sky are cutting back on SD channels so  customers have to upgrade their package they should at least inform their customer officially of this.
@Hillfort
Costs will be governed by Channel 4 not Sky.
Did you try the channel I mentioned?
Avatar for Hillfort
Level 2 icon
  • I have Sky Q. film 4 and +4 were on channels 313 and 314 but now they say No Satellite signal. All other SD channels are OK. I do not have the HD upgrade. I do not see why you get HD on many channels but you are expected to pay an additional sum for say Fim 4 and the sky channels.
Sounds like you possibly have a dish alignment issue as opposed to some conspiracy.
Start here: https://www.sky.com/help/articles/sky-tv-no-satellite-signal
Because that's built into the business model, and would require a substantial increase in the base subscription to replace the lost revenue if removed.
Avatar for Hillfort
Level 2 icon
Hi yes, all film 4 and +4 SD channels state no satellite signal but all other channels are OK. Do not have HD upgrade so do not know if the problem is on HD here as well.
@Hillfort
If you are seeing a message of “no satellite signal” firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s almost certainly a dish alignment issue so check the troubleshooting in the link provided by @PandJ2020
It’s worth remembering that a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
Avatar for Hillfort
Level 2 icon
Hi
All other Sd satellite channels are OK just Film 4 and + 4.
@Hillfort  Channel 4 and it's sister channels such as Film 4 are not Sky channels.
Sky have no control over any channels other than the ones called Sky (in the main)
