Discussion topic: Film 4 +1
This message was authored by: Andy19730
Film 4 +1
Can't receive this channel keeps telling me i have  a problem with my satellite signal .
all other channels are working as normal
Re: Film 4 +1
Please answer the following question so that your thread can be moved to the correct place, where you're more likely to get help with your query
Which Sky TV Service do you have?
  • Sky+ (Satellite box)
  • Sky Q (Satellite box)
Re: Film 4 +1
@Andy19730
As asked by @Annie+UK if you reply on here as to whether you have Sky+ or Sky Q we can give you the correct advice. The advice will be different depending on which you have.
Avatar for Andy19730
Re: Film 4 +1
I have a sky Q box
Re: Film 4 +1
@Andy19730
If you are seeing any kind of ”No satellite signal” related message, check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely either;
▫️a dish misalignment,
▫️a failing LNB (on the arm of the dish),
▫️water getting into the cabling,
▫️it is currently raining very heavily (in which case see if it returns to normal when it eases).
So check the troubleshooting on this link
It may then give you the opportunity to arrange an engineer. If it doesn’t you’ll need to contact Sky to book an engineer appointment.
If you are connected to a communal dish you need to liaise directly with your building management company or landlord who will have their approved engineers to contact direct.
Additionally:
🔹 a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels (amongst the first to be affected may be GB News and CNN),
🔹 a Sky Q box requires a periodic 'Keep alive' signal that is delivered via the satellite so if that isn’t received the box will close down until the satellite signal is restored.
Re: Film 4 +1
If you're in the UK and have no signal on Film 4+1, you should find E4 (SD version), More4 (SD version). 4Seven and Channel 4+1 are also affected.
Re: Film 4 +1
I'm in Ireland and yes those stations  are the same
