Discussion topic: Mini-box not working Error code MR102
This message was authored by: Atomo1
Cannot get mini-box to connect. Have tried re-booting modem, sky box and sky mini-box
Re: Mini-box not working Error code MR102
Hi @Atomo1
Try a Network Reset on the mini.
This message was authored by: Henrygeorge7
Tried switching off at mains for 30 secs still says error MR 102
Have switched off for 30 secs still says error MR102
