Discussion topic: Fibre broadband
Message posted on 27 Aug 2024 01:33 PM
Fibre broadband
Fibre been fitted but my mini box will not connect
Message posted on 27 Aug 2024 01:37 PM
Re: Fibre broadband
Hi @Marilyn70
Reboot the mini as above.
