Discussion topic: Sky saying hasn’t got internet connection
This message was authored by michele-wright This message was authored by: michele-wright
My sky Q is saying no internet connection so can't use any apps or live TV.
I've tried turning it off and on, re-connecting to the router still not working
Re: Sky saying hasn’t got internet connection
Hi @michele-wright
