Discussion topic: Faulty mini box
Message posted on 30 Jun 2025 01:11 PM
Faulty mini box
I recently bought a sky mini box. The engineer has been back twice since he fitted it. All signals ok on router and main tv etc. the mini box is in a bedroom directly over router. Engineers conclusion is mini box is faulty. Could you pleases send a replacement mini box and I will return original to you. I have all original packing.
Message posted on 30 Jun 2025 01:14 PM
Re: Faulty mini box
You can't buy mini boxes - they are lent for the duration of your subscription.
Anyway, we're other customers here and cannot send you a replacement - you need to contact Sky directly.
Message posted on 30 Jun 2025 06:03 PM
Re: Faulty mini box
@Sea+cottage You can contact Sky by phone by dialling 150 if Sky is your phone provider or by following the link below
https://www.sky.com/help/home
scroll down to need more help click on this and you will find a phone number. If you are in ROI please change the flag at the bottom right to the ROI flag
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
