Discussion topic: Downloads and recordings failing due to a technical fault
This message was authored by: BF
Message posted on 30 Jun 2025 01:10 PM
I can't record programs or download content , due to a technical fault.
I also can't view previously made recordings, I just get a blue screen when I select the recording to view it.
Find out more
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 30 Jun 2025 06:02 PM
Re: Downloads and recordings failing due to a technical fault
@BF Have you tried rebooting your main Q box ie
