Discussion topic: Faulty connection no satellite
Message posted on 28 Nov 2023 06:29 PM
All day I've had no satellite reception
Message posted on 28 Nov 2023 06:37 PM
Re: Faulty connection no satellite
What's the onscreen message you're seeing? ”No signal” tends to be a message from your TV (in which case check the cables going to the TV). A “no satellite signal” message relates to your Sky box.
If it displays no satellite signal take a look at the troubleshooting here
It may then give you the opportunity to arrange an engineer to check the alignment of your dish. If you’re on a communal dish system in the UK you’ll have to contact your landlord or building management company rather than Sky.
