Discussion topic: Faulty SkyQ box
This message was authored by: JoyceEzuma
Faulty SkyQ box
The volume no longer works and it glitches and switches off
Re: Faulty SkyQ box
Hi @JoyceEzuma   There is no volume control on a Sky Q box. All the Sky Q remote does is operate your TV or Audio system volume once paired.
Re: Faulty SkyQ box
Hi @JoyceEzuma
First reboot your Q
Then
If you still have an issues with the Q box try a Reset Settings in the Q box hidden menu.
After the Reset you will have to re pair your Bluetooth remote again.
