Discussion topic: Faulty Sky Q box
This message was authored by: Mike439
Faulty Sky Q box
I have had the box for some time (7 years) and it is now showing signs of age. On occasion the sound will fade especially talking so that it can't be heard. At other times the screen will freeze , the only remedy
 is to unplug the the box. and reset up. At other times it will freeze and judder and again the only remedy is to unplug and reboot.
I had to reboot it twice last night. As the problems are intermittent it will not show up on your systems check.
I think a new box is called for.
Re: Faulty Sky Q box
 Possibly but you'll have to contact Sky to ask that.
Remember to remove your viewing card if you do swap it.
