Discussion topic: Fault
This message was authored by: Acky1402
Fault
I can't access on demand services
Re: Fault
Any clues what happens when you try?
Re: Fault
@Acky1402 Sky signature comes with live TV, catchup and boxsets.in SD as standard you may be trying to download the programme in HD
The default download setting is HD so try changing the format to download in SD
you can change the default to SD by Pressing Home on your Sky Q remote and select Settings, then Setup.
Select Preferences, then 'On Demand default download format', and choose SD.
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
