Discussion topic: Fault with cable from dish to box
This message was authored by: Dscott
The cable from my dish to the house has accidentally been cut and will need to be replaced
Re: Fault with cable from dish to box
You'll need to call Sky. Likely to cost £65 for the callout.
...or contact a local firm - this may be quicker but more expensive than Sky.
If you're proficient you may be able to repair the cut yourself?  (Details can be provided here if interested)
This troubleshooter might get to booking an engineer...
https://www.sky.com/help/articles/sky-tv-no-satellite-signal-check-q
This message was authored by: peter-marlow+1966
You could get the cable from  somewhere  like argos  and if you are able replace  it yourself,  ok b&q or any tv electrical  supplier , even amazon  sell the cable and the controllers
P c marlow
