This discussion topic has been answered Discussion topic: Failure to record
Message posted on 07 Apr 2026 05:32 PM
Hi. I have a subscription which includes Sky Witness. On Sunday I wanted to record Watson, it is on series link, it failed to record and it always has before this weekend. It is now saying I need to upgrade to watch Watson. Advice greatly appreciated please!
Message posted on 07 Apr 2026 05:44 PM
Thank you! I've done that and is now downloading. Thank u very much for your help
Message posted on 07 Apr 2026 05:38 PM
Re: Failure to record
if you are now trying to watch from catch up then it is quite likely that the format of the download is not matched to your subscription - i.e. you are trying to download & watch the UHD version without the UHD subscription or the HD version without the HD susbscription.
Check the default download format in
Main Menu -> Settings -> Setup -> Preferences
(Please note this setting can only be set on the Main box)
