Discussion topic: Failed remote network problem
Message posted on 06 Nov 2024 04:11 PM
Re: Failed remote network problem
yeah that slight changed address is just load balancing / round robin.
you get similar to me.
Message posted on 06 Nov 2024 04:48 PM
Well, hard to say, but some apparent progress...
In PC program called
'Simple DNS Plus'...
Tools, options, forwarding...
I set all Domain names to be forwarded to 1.1.1.1
(Mark would be proud)
Then
Tools, plug ins, add...
(Suspect Network experts will be cringing now)
I added a host file, which I noted was created at
C:\windows\system32\drivers\etc\hosts
And in it I put the lines
a2047.sky.akamai.net 87.248.204.0
And
ondemand.cdnselector.skycdp.com
And kinda made this bit up, but selected 'process DNS requests' 'only when the following is true'...
That the requested domain is on-demand.cdnselector.skycdp.com
I've since downloaded over 100 hours of TV without issue
We await feedback on my fix and whether I've stumbled upon the answer of am just having a good server afternoon!
Either way, don't think I'm too far off!
Message posted on 06 Nov 2024 04:51 PM
Yeah that text file is a standard windows system file for hosts that it knows about so not surprised SimpleDNS defaults to it for that purpose.
and it really is as simple as
hostname IPaddress
although DNS is more complex than that and has different record types but out of scope for this discussion.
Message posted on 06 Nov 2024 05:13 PM
But is your feedback that I've done it right?
What's interesting is clearly the mini PC IS involved...the activity log proves that
Occasionally the Sky GUI is showing no internet, but instead of the download failing, it carries on after the Internet pops back
Seems I may have cracked the cases which should help me set up the router when it arrives.
I'm not ready to mark this as the solution as I might just be having a coincidental good run, but....
Message posted on 06 Nov 2024 05:55 PM - last edited: 06 Nov 2024 05:59 PM
Yeah it seems right, not knowing that software.
You should try adding that other IP address that was almost the same onto the end of that line in the hosts file to set up your own little round robin 😉
Message posted on 06 Nov 2024 06:33 PM
Now we are deep into the theory...My area of interest is A.I
I laid out the problem and asked it for it's take. It took the opposite approach to the one we have been playing with.... suggesting I establish exactly which IP addresses cause the issues (we know them) and then block them. It gives explicit instructions on how to do so in Windows Firewall Defender.
When I queried it, asking would blocking those result in a download from the one working address, it simply replied...'try it and see'!
Bloody robots
Message posted on 06 Nov 2024 06:41 PM
Btw,
Does anyone know what happened to Mark? His profile seems to have disappeared? Think he may be coming up as 'anonymous'
I hope he hasn't disappeared the day before my router arrives!
Message posted on 06 Nov 2024 06:53 PM - last edited: 06 Nov 2024 06:58 PM
@Craigv9 wrote:
Btw,
@Craigv9 when a profile comes up with anonymous it usually means the person has deleted their account
Message posted on 06 Nov 2024 06:56 PM
Ok, thanks. He's still here, though which is the good news!
Message posted on 06 Nov 2024 06:57 PM
Bloody robots
This is why we will always need humans.
Message posted on 06 Nov 2024 08:00 PM
What I have done, it seems and I'm no expert, is somehow forced a retry, retry, retry, if a download fails or goes to a hooky server...
The Sky GUI goes loco with 'you're not connected to the Internet' messages and states download failed, but doesn't give the 'failed: remote network error' and eventually succeeds
Providing it's actually the fix and not random luck, this appears to be a perfectly serviceable solution for anyone with a PC on their network, and his software, albeit it's a paid download
I may well try the alternative firewall solution tomorrow which doesn't need the program, to try and remove the PC program from the equation. And when the router arrives try that too...that will give 3 similar but varied options for people moving forward...
I've never been known for half measures
Meanwhile Sky and Kloud9 are co-opersting towards a solution...doubtless reinventing the wheel and comparing the size of their floppy disks and hard drives...
Message posted on 06 Nov 2024 08:11 PM
Try, in the SimpleDNS config, changing the address you're forwarding all the other DNS requests to, from 1.1.1.1 to the address of your router. See if that changes the behaviour.
Message posted on 06 Nov 2024 09:26 PM
Interesting...will do...I'll report back...I'm hoping the other router arrives tomorrow...
Message posted on 07 Nov 2024 09:07 AM
By turning my PC off, closing down Simple DNS Pro, changing the DNS settings within Simple DNS Pro and the Sky Box alternitively, and by monitoring the Simple DNS pro activity log I have confirmed BEYOND DOUBT that this is a solution (which we knew anyway, thanks to Mark and Chodley)
If you have a PC on the same network as your Sky Box, then it really couldn't be much simpler
So, using a PC with Simple DNS Pro will be the first solution
I appreciate that not everyone has a PC on their network, so we need a Plan B
That arrives in the form of buying an old router with the type of user accessible settings that you don't get on routers these days and messing with those settings...(I bought such a router and the necessary lead for under a tenner...)
By the close of play today I hope to post both solutions in user friendly terms to assist everyone moving forward...though I may need the help of Chodley and Mark to get there!
It's been a long road! The next battle? SKY Q has a 'delete all' settings for recorded programs, but does not have a 'delete all forever' option...what's THAT all about?
Message posted on 07 Nov 2024 12:38 PM
My router has arrived!
