Discussion topic: Extra sky box not working
Message posted on 01 Jun 2024 09:21 PM
Done all the usual things but sky box not working
Message posted on 01 Jun 2024 09:25 PM
Re: Extra sky box not working
Hi @Rach42
Reboot the mini as above.
