4
This discussion topic has been answered Discussion topic: Export program
This message was authored by: penfold72
Export program
Is it possible to export a recording from the q box to a memory stick or other external device. My wife is going to be on TV over Christmas and I wanted to store the recording on my laptop so it doesn't get lost.
Re: Export program
No, absolutely not.
That's simply not an option from Q.  If the broadcast is on a free to air (unencrypted) channel then some television sets permit 'recording' to external storage from signal received into a satellite or digital terrestrial tuner contained in the set itself.
Re: Export program
No, absolutely not.
This message was authored by: PeteRG41
Re: Export program
You can select the "Keep" option on a recording once you've recorded it on Sky Q.  This will prevent the programme from being deleted accidentally or being deleted through aging.  The recording will, however,  disppear if Sky lose the broadcasting rights to the programme in hand.
There are other ways of retaining a more permanent copy of the programme, but this would be piracy (even for personal use) and therfore outside the remit of this forum.
____
Pete.
Re: Export program
And when Q becomes obsolete in a few years time.
Avatar for penfold72
Level 4 icon
Re: Export program
Ok. Thanks for the replys.
Answered - Go to Answer
