Discussion topic: Excessive wait time for an engineer booking
Message posted on 21 May 2025 10:32 AM
Re: Excessive wait time for an engineer booking
@John+Scott+Latty wrote: unpatched my coaxial in the shared cab and repatched
As you are fed from a communal Integrated Reception System installation, and your Sky Q receiver is therefore correctly reporting that it has no satellite signal when configured to be in Wideband LNB mode, you will now need to configure your Sky Q receiver back to Single Cable Router (SCR) LNB mode, instead of the default WideBand LNB mode.
Thus, to configure a Sky Q receiver to use SCR LNB mode;
Press Home
Scroll to Settings - but do not press enter/select at this point
Press 0 0 1 in sequence followed by the Enter/ select button
you should now get the engineer's menu
Select the LNB Type & set to SCR
After changing the LNB type, switch to standby, and finally remove mains power from your SKY Q box, then restart it for the change to come into effect
Godfrey.
