Discussion topic: Ethernet connection
Message posted on 20 Sep 2023 02:38 PM
Ethernet connection
If I hardwire Sky Q to router with Ethernet cable and reset it will it disable my 2 miniboxes?
Message posted on 20 Sep 2023 03:09 PM - last edited: 20 Sep 2023 03:09 PM
Re: Ethernet connection
@Tony54 wrote:If I hardwire Sky Q to router with Ethernet cable and reset it will it disable my 2 miniboxes?
No, as your mini boxes will be connecting to the main Q box via its own wireless network.
Message posted on 20 Sep 2023 03:42 PM
you will find though that the Q will not use ethernet reliably while it also has wifi enabled.
